Miner
3D materials/Texures
Does anyone have a good source for getting additional modeling textures to add to Archicad?  I've looked at BIMcomponets.com and found that to be very limited in selection.  And many occasions that link doesn't work anyways.
Archicad 28 Solo
iMac 27" 3.8GHz i7
8GB RAM
4 Replies 4
Miha_M
If you are on a SSA subscription (or whatever it is called now), you can get additional textures.
Additional Surface Catalog for SSA Users - Graphisoft Community
| Archicad 4.5 - 29
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
Miner
Thanks!  Found some more useful texture doing that.
Archicad 28 Solo
iMac 27" 3.8GHz i7
8GB RAM
DGSketcher
Legend
@Miner Do you know AC has a built in catalog of additional surface textures?
Go to Options > Element attributes > Surfaces, then Select "New" and then "New from catalog" and you can search for a range of surfaces that aren't used in the default Building Materials.
Gerry Leonor
you can also use ArchiTextures:
Create — Architextures
it's quite a powerful tool/site to use.
https://discord.gg/XGHjyvutt8
