AC 22 - POSSIBLE BUG: Label tool text shifted leftward
When working with label tool in AC 22, sometimes the label tool text shifted leftward by itself. In my case, it happened after i opened a 3D perspective view and then opened floor plan view.
Current solutions:
1. It shifted back to its correct position if i changed any of the wall settings
2. selecting all the label > ctrl+t>ok also fixed the problem temporarily
4 Replies 4
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello,
Seems pretty interesting. I couldn't reproduce it myself, so there must be something about your file/template/computer specifically.
Does using Rebuild & Regenerate (Ctrl+Alt+Shift+R) fix it?
I recall something similar happened with ARCHICAD 21 and 4K screens - maybe you have a 4K screen?
Do you have a file you can reproduce this in easily? (like if you open 'View A' and then go back to 'Floor Plan B', it happens)
If you do, could you send it over to me in a Private message so that I can try myself and see if it is indeed a bug?
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
gpowless
This bug is not project specific and has been around since 21, through Beta to 22 4005. It occurs on all sections or elevations that have been closed and then reopened.
Since it doesn't affect publishing I have learn just to select all, change the leader connection (top or bottom connections) and revert back to default. This cleans it up.
Intel [email protected] 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
i don't have a 4k screen, but i do work on my surface pro laptop (2736x1824p) connected to an external monitor (1920x1080p)
-John
strangely enough, it only happened to me once i used ACC 22
-John
