2021-04-20
05:42 PM
2023-05-19
03:44 PM
Gordana Radonic
2021-04-20 06:32 PM
2021-04-26 03:47 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-05-18 05:40 PM
2021-05-19 03:21 AM
2021-05-19 11:38 AM
2022-10-27 03:58 AM
I have just seen this problem but Save As method also ends up the same with none of the level dimension text appearing.
2022-10-29 04:03 PM
This is quite an old bug as I recall it. The bug appears randomly, but when it catches you it won't go away. Don't know the cause of it, but for us changing all text from Helvetica to Arial on a Mac Archicad, pdf's print fine again through Archicad publishing.
