Read more
AC25 surfaces preview bug?
Paul King
For some reason when I create a new surface, even if I duplicate the 'Exposure to light' parameters exactly of another surface, the resulting preview is always either glaring white, or pitch black
Below is a standard built in Archicad colour - preview is fine.
This is a colour I made by duplicating another colour (also with an ok preview)
Why is this?
How do I fix already defined new surfaces exhibiting this issue?
(I tried the workaround of duplicating and re-defining another colour not exhibiting the issue - but  the result in the duplicate is always glaring white or pitch black preview - and same appears in the surface painter pallet, and neither bear any resemblance to the colour as displayed in 3D view )
Is this a known bug?
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
I don't know why it appears so different, but your shininess is 75 instead of 50 and the specular colour is slightly different.
Thanks Barry - sorry you are right (pasted the wrong version) - but even tweaking these makes no difference.
Thought I had a workaround, but turns out not to work.  Sadly the forum software wont let me simply delete this post.
