Royal_M
Adding new objects
I am using AC SE 21. I downloaded few objects from BIM components portal, but when I try to upload them in my AC library the objet selection is inactive. Can anyone guide me on this? Thanks in advance.
Are the objects compatible with SE 21?
I believe that is base on AC24, so if the objects are version 25 then you won't be able to use them.
Did you download directly from BIMComponents - in which case you have to make sure they are compatible.
If you access BIMComponents through Archicad SE (through object settings > search), then they should be the correct version for that program.
