2020-03-26
03:46 PM
2023-05-19
03:46 PM
Gordana Radonic
2020-03-26 05:48 PM
Kris wrote:
Align texture fill/hatch) Is there a way to align your 2D texture/fill? I have created a brick pattern fill which I have applied to my wall. Anyhow, the pattern doesn't start where it should. Is there a way to specify an origin for the fill?
Dimension marker) I want to place a level dimension measure on my floor plan. I'm doing this with Level Dimension Tool > Level Dimension > selecting this marker: markertype.png
Anyhow, the problem is that the text aligns only to the right side of the marker. If I want to move text to the left side, the marker will overlap with the text. markertype2.png
2020-03-27 12:49 PM
LaszloNagy wrote:Ok so there are two things. The first is that the fill doesn't start from the edge of the wall but leaves a narrow gap in-between.
Could you show me on a screenshot how this looks now and what you would like to achieve?
LaszloNagy wrote:I tried to mirror it from the cross (clicking the dot at the center) and it would still overlap. Could there be something in the marker options that I'm doing wrong?
You can select the Level Dimension and mirror it at the center of its cross. Then the Leader line will also get mirrored and will not overlap the Dimension Text.
2020-03-28 08:01 PM
This is what the fill looks like
Kris wrote:
And here's the second problem. Fill starts from a different point on floor 2 than it does on floor 1. The problem might be that the walls in two floors connect to each other differently? Although I don't know why and how to fix it (see image 2).
2020-03-28 10:31 PM
