Hi Luke,
Thank you very much for your report and I am very sorry about the issue!
This is a known issue with Archicad 24 (please refer to it as DEF-3025). It is an issue with the Pointer in Label Tool when there is an Autotext within the Label Text with these Pointer Settings :
-"Middle Pointer Line Connection"
-"Connect Label to First Row" or "Connect Label to Last Row"
On the Layout, after placing the view with the Label, the results are incorrect, as the Pointer of the label isn't centered on the top line of text as it was supposed to.
Unfortunately, there is no target date set for this issue yet. I will add your request into the report, hopefully, it will receive a higher priority for fixing.
I am very sorry for the inconvenience, and thank you very much for your understanding! Please let me know if you have any further questions!
Best regards,
Minh
	Minh Nguyen
Technical Support Engineer
GRAPHISOFT
