SOLVED!
Archicad 25 elevation markers, horizontal range limited, fills area in floor plan
Project started from AC25 INT default template. Those yellow fills appeared when I turned on “horizontal range limited”, and I can't find where to get that back to clear.
1 ACCEPTED SOLUTION
Solution
You can turn the fill off in the On-screen Display Options > Highlight Source Markers.
The actual fill colour is set in the Work Environment > On-screen Options > Source Marker Colour.
2 REPLIES 2
Solution
Thanks! I had seen that in Work Environment settings, didn't understand what it was meant to do, and figured I'd turn it on to learn. I couldn't find it in Documentation, searched for all the wrong words.
