ā2022-08-11 10:41 AM
I've been working in Archicad for 7 years and I've never had such case. Archicad changed font style of workspace. I have no idea how it happened and how to return it back.
Solved! Go to Solution.
ā2022-08-15 10:30 AM
Thanks for replying to each of us (just the one reply would be enough though).
The problem is, installing a new font should not affect the default system font in Archicad.
It should just become a new font that you can use for text in Archicad.
I am not sure of a permanent solution.
What will happen if you need to install that font again or install another font?
Maybe it is that particular font?
Maybe it is the way you install the font (on Windows I just copy the font file to the WINDOWS > FONTS folder).
I guess the only way to find out is to install another font.
At least you know if you delete it, all goes back to normal.
ā2022-08-15 10:39 AM
But wow. This helped me a lot. Thank you.
