Tim Ball
Autotext Dimensions
Came across an odd problem with Autotext.
I was labelling the height above storey level of an object and the units were only available as m to one decimal place. The dimension preference settings made no difference to the reading.
I changed the Length setting in calculation rules from m to mm and the height showed up fine. However I can't see a way of preserving that under preferences.
Tim Ball
AC26, iMac
User since V5
0 Replies 0
