cocoloco
Bug - archicad won't let me rename elevation name
Hello,
I happen to run into what must be a bug. Otherwise I can't explain. Named room & elevations name correctly, but it re-name it to "master suite" even after changing. basically it does not let me rename the elevation. I was ok with it but because it shows now wrong on floor plan (totally different room) obviously I don't want to represent it.  every new elevation is called master suite (BUG) even after or prior renaming it... UGH
Operating system used: Mac Apple Silicon 14.5 Sonoma
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
1 Solution
cocoloco
nevermind aparently a fixed bug in an update 😄
Go to post
cocoloco
