‎2006-10-19
05:13 AM
‎2023-05-30
10:08 AM
Rubia Torres
‎2006-10-19 05:47 AM
s2art wrote:hi stuart
Is there a way to get the Autotext to not read from a particular drawing. I have looked for a check box (in drawing settings within layout) to this effect but found none.
Anyone else think this would be a good idea?possibly. 'back-referencing' autotext . . ?
‎2006-10-19 06:33 AM
~/archiben wrote:Nope. It just reads both values automatically.
does the order of which the drawings appear in the layout's layout map make any difference to your situation.
~/archiben
Link wrote:Yeah, that would work, but just sounds slightly less than automatic. Back in the "olden" days (read AC/PM9) I just put scale in manually and tried to remember when to change it. Similar amount of effort required.
Not sure how much this is going to help you mate, because your autotext is on the master layout.
If it was on the layout itself, you could right click on the drawing whose scale you did want, and select 'Set as Autotext Reference'. Then you could edit the text and from the Insert Autotext dialog, choose the 'Reference from...' Category and the 'Drawing Scale Ref.' autotext.
But since the autotext is on your master, you may want to get the Twink out (solid white fill)!
Link.
‎2006-10-19 06:55 AM
s2art wrote:its for that very reason I dont put scales in the title block but append then to each drawing
‎2006-12-19 01:58 AM
‎2006-12-19 02:40 AM
‎2006-12-19 03:57 AM
