Commas In Dimensions?
Hi, when i dimension i am getting annoying commas in the actual figure, how can i remove this?
11 REPLIES 11
I don't think you can.
Brett Brown
Yes you can. In XP goto Control Panel/Regional and Language/Regional Options and get rid of comma there.
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
Thanks, it worked.
Aussie John
On the mac you used to be able to change the system prefs ( international) but last time I tried this didnt work.
Cheers John
[/size]
Brett wrote:
Yes you can.
Good.
on WIN it is easy,just in reg. options,but on Mac i wanted space as thousands separator and i needed 2 days typing in terminal to get that,stupid.
Best Samp Regards!
Try This it works 1 525 instead of 1,525 etc. Hopefully it will be fixed in Lepoard discussions.apple.com/thread.jspa?threadID=714859&tstart=0 but if you stufff it up call apple support not me
Gerald D Lock
I followed the link to the thread at discussions.apple.com.
Very interesting info & a 'work-around' fix for the problem (I'm sure all archiCAD users will be very familiar with 'work-arounds'
The fix does replace the comma with a space in dimensions, but unfortunately, I've found that it also puts a space in place of a decimal point, so that decimalised input fields etc. read strangely eg. 100.00 would show in the input field as 100 00
When will Apple fix this...? (cos it's an OS X issue, not an ArchiCAD one) ...who knows...
ArchiCAD 24 (build 5004)
MacBook Pro (16-inch, 2021) Apple M1 Pro 32GB RAM | MacOS 12.0.1
Melbourne, Australia
im in that options window but what do i do to remove the comma?? i tryed customize, but when i remove the comma it says its an invalid selection
