Complex Profiles
Brett Brown
Hi, Could someone tell me how to get the hot spot to stick on a edge of a profile so it is selectable as a dimension point(In the editor). I put a hot spot on an edge I want to dimension to, but it is not live in plan. Only live points in plan are the origin and the outer most edges. Did Store the profile after adding the hotspot.
1 REPLY 1
David Maudlin
Brett:
I have had no problems adding hotspots to Complex Profiles that are visible and are selection points in plan and elevation, you may need to post more information about your problem.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
