rm
Composite walls outside corners not displaying properly
Hi -
Something tells me I just am missing some sort of preference setting. Please look at my attached image. None of my composite wall outside corners are closing completely when displaying true line weights. If I turn off true line weights, they look correct and close up properly
What am I missing here or doing wrong? BTW, if I don't use composite walls, using single fill walls, the corners also cleanup and close properly with true line weights selected.
[attachment=0]Screen Shot 2018-10-04 at 7.54.05 PM.jpg[/attachment]
Thanks for your input!
Robert Mariani
MARIANI design studio, PLLC
Architecture / Architectural Photography
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
20 Replies 20
Jakub Nohejl
Hello All,
I would like to add on more situation which happened in this topic. When we want create basic wall which has two different outlines pens we use Composites as only way how to do it. However there is similar problem with corners. I send you video record in attach. Only way is create 2 composites with different setting.
I understand that the Composites tool isn't especially create for this but we can not find any other way how to do it in AC.
Best Regard,
Jakub
