2022-05-02 09:33 PM
AC25
Lets say I have just created a new section B and I have opened it to the current screen settings.
Then, using the view map I open existing Section A in a new tab.
Section A has the view map settings I want to use for section B.
So I right click on the Section A Tab and select copy view settings.
Then I right click on the Section B Tab and select inject view settings.
At this point only some of the screen settings for section B are changed to match the view settings for Section A. The scale and the dimension settings for Section B remain as they were.
I figure copy view settings should mean copy all of the view settings but it doesn't.
Is this by design??
Does anyone have insight into this??
2022-05-02 11:38 PM
@gdford On macOS the dimensions update but not the scale. Looks like a case of incomplete development of the transfer function. I would report it as a bug.
2022-05-03 04:10 AM
Seems it might be by design.
In the reference guide, it doesn't say specifically for pick up / inject settings, but for match settings, it does not include scale or zoom.
2022-05-03 06:47 PM
I never would have thought that would have been documented!!
