Learn more
gdford
Copy/Inject View Settings
AC25
Lets say I have just created a new section B and I have opened it to the current screen settings.
Then, using the view map I open existing Section A in a new tab.
Section A has the view map settings I want to use for section B.
So I right click on the Section A Tab and select copy view settings.
Then I right click on the Section B Tab and select inject view settings.
At this point only some of the screen settings for section B are changed to match the view settings for Section A. The scale and the dimension settings for Section B remain as they were.
I figure copy view settings should mean copy all of the view settings but it doesn't.
Is this by design??
Does anyone have insight into this??
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
3 Replies 3
DGSketcher
Legend
@gdford On macOS the dimensions update but not the scale. Looks like a case of incomplete development of the transfer function. I would report it as a bug.
Seems it might be by design.
In the reference guide, it doesn't say specifically for pick up / inject settings, but for match settings, it does not include scale or zoom.
gdford
I never would have thought that would have been documented!!
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
