Cut plane problem
Maybe someone has solved this one:
I have a plan with a short wall (4'-8"h) beside taller wall.
The tall wall has a window with a sill height of 4'-9".
I want both walls to appear "cut" and the window to appear in plan. If the cut plane is set to cut through the window (4'-9" or higher) then the short wall is not cut. If the cut plane is set to cut through the low wall then it is below the window...you see what I mean.
A gold start goes to the first person to solve the problem. 😉
Thanks,
20 Replies 20
Thomas Holm
Eric wrote:
When the wall was set to cut only and the window was set to symbolic only the wall showed. If the wall was set to projected and the window was symbolic the window was visible.
Then it works the way it should. I guess I really got confused before. Sorry!
