We value your input!
DImension in sheet do not match dimension in layout
Hello.
I have a problem with dimensions. In layout they are shown correctly in millimeters but in sheet they are show in meters. I would like the dimensions in sheet to also be in millimeters. How can I change that. The sheet updates automaticaly if I make a change in the layout, but the diemnsion unit stays the same.
You should be creating views that you place on the layouts.
Those views have settings that contain the layer combination, pen set, graphic override, renovation filter, etc.
Another of the settings is the dimension style.
So make sure your view has the correct dimension style set.
Thank you. It worked...
