Another trick you can use is to place a Linear Gradient Fill in your Elevation.
Make the Fill Pattern Pen white, make the Fill Background Pen transparent (0).
Bring the Fill in Display Order to the front so it will cover other elements.
Then you just need to modify the gradient handle line of the Fill.
This will give a gradient effect that is the same as in Revit.
