2003-12-01 07:39 PM - last edited on 2023-05-17 07:45 PM by Gordana Radonic
2003-12-02 12:23 AM
YA.H.VE wrote:The fill you see is the result of a hidden parameter in the script and the change in index numbers for fills. To correct the problem you have to open the library part, make the fill parameter visible and save the part. This will mean that you will have to unpack the PLA library and revert to the old way of storing the ArchiCAD library in folders. The dimensions inside a detail should be set to static dimensions. That way they won't disappear when you re-build the source view.
...the "Detail Indicator NCS" shows a "common brick" fill ...ALL MY DIMENSIONS GONE....
Yamil
2003-12-02 04:00 PM
