Details! Is there a way to batch rebuild from source view?
Karl Wir_n
Is there a way to rebuild several details from source view? I am only able to do this one detail at the time, by right clicking and choosing "Rebuild from Source View". Using dropdown menu View->Refresh -> Rebuild from Source View has the same result, only one gets rebuilt. //Karl
In the Project Map or View Map, select the 'Details' folder and right click.
Strange that you can't select more than one detail in the list and do this.
Thank you @Barry Kelly for a quick response! /Karl W
Setup info provided by author
