Dimension Lines disappear on layouts sheet
Hi everyone,
I have some prepared views for a sketch design, and there are annotations of automatic dimensions for walls. Those annotation are visible in the views (save in teh views map), and their layers are part of stored layers combination. Nevertheless, in the layout where those views are loaded, the dimension-s line are not visible anymore, only the lines, the values are still visible!
any ideas??
thanks
Antonio
1 Solution
SOLVED
checkbox -Show dimension text only- in Dimension Selection Settings panel
Go to post
SOLVED
