‎2006-08-09
11:59 AM
- last edited on
‎2023-05-30
03:24 PM
by
Rubia Torres
‎2006-08-09 12:11 PM
‎2006-08-09 12:46 PM
‎2006-08-09 01:55 PM
‎2006-08-09 02:30 PM
‎2006-08-09 03:16 PM
‎2006-08-09 04:00 PM
andrewzarb wrote:Dozens? The surveyors you know must be very frugal with their layers. I have seen civil drawings with well in excess of one hundred.
...The dozens of layers that surveyors use can usually be satisfactorily whittled down or merged to a couple.
‎2006-08-09 05:37 PM
areffoios wrote:You're welcome! That's exactly what I meant.
I've found how to do it, anyway thanks for your help. Here it goes:
Tools - Configure Translator - and then change from mm to m. And then import the file. It worked with me.
‎2006-08-09 05:45 PM
areffoios wrote:You already found the solution, but just so you know, that bug only affects dwgs EXPORTED from Archicad. If applicable, they will scale wrongly in Autocad. This is a bit special, seems to only affect certain configs where the Autocadder has a (global?) INSUNIT (setting) which is different from his DWGUNIT, and it's easy to fix if you're fluent in Autocaddish. I'm not.
Thanks for replying! I'm the sender... I had the file in Acad and now I want to do a 3D model in Archicad, but the problem is that I have changed the units from m to mm and still i haven't seen any difference! I'm using Archicad9, can this be related to the bug you wrote about, in the post you recommended me?
‎2006-08-10 04:14 AM
Matthew wrote:Layers can sure be a problem.andrewzarb wrote:Dozens? The surveyors you know must be very frugal with their layers. I have seen civil drawings with well in excess of one hundred.
If you only need the survey as a reference you can also place it as a drawing (in AC10). That way there are no layers (or linetypes etc.) added to the project attributes, and you can easily rescale it.
