‎2021-05-17
05:37 PM
- last edited on
‎2023-05-30
09:53 AM
by
Rubia Torres
Solved! Go to Solution.
‎2021-05-17 06:45 PM
LOUTRO wrote:And definitely not good practice! Archicad has a way to do what you want using the User Origin. Go to your section / elevation, add your required elevation level dimensions. Place the user origin at the required height, then select the level dimensions you want to change and in the drop down for the Dimension Origin select Current User Origin. The selected elevation dimension levels will now be displayed relative to that point.
I discovered that I can override the dimension by right clicking on the dimension text then setting a custom dimension, but this of course is not dynamic.
‎2021-05-17 05:45 PM
‎2021-05-17 06:15 PM
‎2021-05-17 08:10 PM
