Dimension text disappearing when changing storey
Hi all,
I have a strange problem which I can't figure out.
When I put text on a dimension, "<MeasuredValue>¶win" to denote that the distance is the width of the opening, it will occasionally disappear if I change to the subfloor storey and then back to my ground floor storey.
It only disappears when I use the View Map, if I use Ctrl+F2/Ctrl+F3 to go up and down storeys it stays there.
I should also mention, it doesn't happen to every piece of text on the same dimension string.
Does this happen to anyone else?
AC21, pretty sure it's up to date, Windows 7 Pro
6 REPLIES 6
Lingwisyer
Guru
If it is disappearing only when you used the View Map, it sounds like a layer display issue... though I did not know that text within an object could be on multiple layers, more so text within a single line... I do not recall there being a MVO option for text. So, check whether the relevant text layers are active in your Views Layer Combination.
Ling.
AC22-28 AUS 3001Help Those Help You - Add a Signature
It only happens to certain pieces of text on the same string of dimensions, so I doubt it is a layer issue?
Also, if I were to go to the first floor and then back to the ground floor in the view map, everything is still there.
It only seems to be when I go to the subfloor (storey No. -1, elevation -325) that some text disappears.
Does anyone else have an idea of what could be causing this? It doesn't present well on construction drawings when text is missing.
It's just a guess, obviously, but I'd look at your dimension styles, which are saved with the View Map. It could be that the View where the dimension goes missing has acquired a strange dimension style, which gets changes when you access it through the View Map, but wouldn't change when just go up or down a story.
Richard
AC26 (since AC6.0), Win10
JaseBee
Dimension text positions can display in different positions at different scales... could be that, or maybe a Reno filter option... seems odd though.
AC 24 5004 AUS
iMac OSX (10.13.6) 4.2ghz i7
8gb ram/8gb vram
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello FroDaddy,
I think this might be what you are looking for:
https://archicad-talk.graphisoft.com/viewtopic.php?t=58638
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
