Dimensioning issues in AC 28
Bob Moore
Having an issue with dimensioning in AC 28. Figure 1 shows the floor plan with nice even dimensions. Figure 2 shows the plot with dimensions down to 1/64 an inch. Why would AC change them? All the dimension preferences match.
Operating system used: Mac Intel-based Sonoma 14.6.1
AC 7 - 27
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
Jeff Thompson
Looks like you have the wrong dimension style saved in your view settings of that floor plan view after you've placed it on your layout.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
4 REPLIES 4
I suppose that the first shot is coming from project map & the other is coming from view map so you only need to adjust the view settings including Dimensions.
AC 28 INT 3110/WIN 11
Jeff Thompson
Project Manager
Thanks
AC 7 - 27
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
Those dimensions at the higher accuracy indicate that the distances may be modeled inaccurately. It would be best if you modified them so the values are multiples of feet even at the highest dimension accuracy setting.
Setup info provided by author
