This one caused me a bit of grief today.
Thought I'd share...
I started using a new template in AC22
and very time I tried to dimension a string
of composite walls (Linear: in Plan View), I couldn't get past the first wall.
It would dimension the core and then I couldn't click the next wall.
If I clicked nodes, I was OK.
Finally found (by reading the manual
) I had the
"Geometry Method: Single-Click Thickness" button highlighted.
Never knew it existed. Magically appeared in AC21 (I think).
You won't see the button in the Dimension Tool's Dialog Box.
Only in the Info Box.
Marc Corney, Architect
Red Canoe Architecture, P. A.
