FONT SIZE in Zones
Is it possible to change the size of font in zones based on scale sensitivity?
I want my zones to different behave when I change scale. I do that perfectly with adding and removing contents. But font size allways stays the same. For example if i set zone name is 3mm it stays allways 3mm in every size.
I want to set that it is for exaple 2mm in scale 1:50, 3mm in scale 1:100 and 4mm in scale 1:200. Can I do that:?:
There are settings for paper and model size (but that is not what I'm looking for).
Those are the settings that allow you to have scale sensitive text though. With one, the text scales up or down with the model elements, with the other the text is always the same size regardless of model scale...
There is no option to specify exactly the size that you want for each model scale... that would require coding a custom zone stamp in GDL.
Palawat
You might want to try this ;
https://www.indigofigs.com/zone-stamp/
Archicad 29, Windows 10, Corei7 3.4 GHz, 32 GB Ram.
https://www.facebook.com/indigofigs
