Dimensions Changing
I think I recall this being discussed earlier (I did do a search, but came up with too many hits), but when I set dimensions to read 1'-0" after some time it will revert to 1'.
This does not happen with the other dimension settings and only seems to happen infrequently and not on a regular basis. Has anyone come across this and is it a bug? Not a major problem, but kind of annoying.
Thanks,
Don Lee
2 Replies 2
Hi Don,
Dimension formatting is part of a saved view. Under Options > Preferences, set up names for the different formatting that you might want, if more than one. Then make sure that each saved view refers to the proper, named dimension settings.
HTH,
Thanks Karl!
Don
