Level Dimension Tool
Using the level dimension tool, I'm not able to change the settings of the height.... It doesn't give me any options to change it??
it shows only the original level of the floor....
5 Replies 5
Click the Dimension Text itself, not the Dimension Sign/marker. Then the Info box and the Settings Dialog will give you different options and you will be able to modify the value to your liking.
Thanks a lot laszlonagy,
Always helping me
or u could use the gravity tool and the level dimention will never be wrong 😉
Hummmm I never use this tool... and don't know how hhehehe I will search how to 😃
Thanks for the tip
I searched for the gravity toll and saw that it doesn't helped me in the project because I need to put level dimensions even on stairs , not only the slabs, but thanks for the tip
