2008-12-0412:16 PM - last edited on 2023-05-3003:17 PM by Rubia Torres
2008-12-0412:16 PM
Using the level dimension tool, I'm not able to change the settings of the height.... It doesn't give me any options to change it??
it shows only the original level of the floor....
Click the Dimension Text itself, not the Dimension Sign/marker. Then the Info box and the Settings Dialog will give you different options and you will be able to modify the value to your liking.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
I searched for the gravity toll and saw that it doesn't helped me in the project because I need to put level dimensions even on stairs , not only the slabs, but thanks for the tip
