Dimensions reveresed in Archicad
Hi, have a problem with the dimensions reveresed in Archicad. ie. should read 6'7" (6 feet 7 inches) but reads "7-'6.
This had occured on Thursday morning.
We have attempted system restore in windows but it failed. I have found on another forum that it might be linked to locale (the example was on a mac).
If this document is viewed on another computer in the office then it appears the correct way. This problem only occurs in Archicad 7 although we have version 10 this problem is not replicated.
Thanks for all your input.
Best wishes, Jason
David Maudlin
Jason:
Could it be a system language setting that reads from right to left rather than left to right?
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Djordje
It most definitely could be. Switch the support for Arabic and Hebrew off - should work.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
