2026-08-15 03:21 PM
Hello Archicad Community,
I am experiencing strange behavior with the 2D Plan Preview field in an Interactive Schedule in Archicad 29.
I set the preview scale to:
To Fit (≤ 1:20)
Initially, the schedule displays the 2D element correctly at approximately 1:20. However, the following happens:
Open the Interactive Schedule.
Select the 2D Plan Preview cells.
Set the preview scale to To Fit (≤ 1:20).
Confirm that the previews display correctly.
Return to the Floor Plan.
Reopen the Interactive Schedule.
After reopening the schedule, the preview graphics appear to have changed to approximately 1:100, even though the formatting panel still shows To Fit (≤ 1:20).
The interface therefore reports the correct setting, but the displayed preview uses a different scale. Reapplying the same scale setting temporarily corrects the previews.
Has anyone experienced this behavior or found a permanent solution?
Could this be related to:
Schedule cell dimensions
Schedule regeneration
Model View Options
Saved View settings
Drawing scale
A preview-cache or schedule-refresh issue
Thank you.
Solved! Go to Solution.
2026-08-15 04:29 PM
You should have a 'View' created for the schedule so you can place it on your layouts.
Check the scale in the view settings.
2026-08-15 04:29 PM
2026-08-17 07:28 PM
YES!!!! I knew it was somewhere!!!
That you Barry. Has a nice week.
