iggiv
2D Plan Preview scale changes unexpectedly in Interactive Schedule
Hello Archicad Community,
I am experiencing strange behavior with the 2D Plan Preview field in an Interactive Schedule in Archicad 29.
I set the preview scale to:
To Fit (≤ 1:20)
Initially, the schedule displays the 2D element correctly at approximately 1:20. However, the following happens:
  1. Open the Interactive Schedule.
  2. Select the 2D Plan Preview cells.
  3. Set the preview scale to To Fit (≤ 1:20).
  4. Confirm that the previews display correctly.
  5. Return to the Floor Plan.
  6. Reopen the Interactive Schedule.
After reopening the schedule, the preview graphics appear to have changed to approximately 1:100, even though the formatting panel still shows To Fit (≤ 1:20).
The interface therefore reports the correct setting, but the displayed preview uses a different scale. Reapplying the same scale setting temporarily corrects the previews.
Has anyone experienced this behavior or found a permanent solution?
Could this be related to:
  • Schedule cell dimensions
  • Schedule regeneration
  • Model View Options
  • Saved View settings
  • Drawing scale
  • A preview-cache or schedule-refresh issue
Thank you.
1 Solution
You should have a 'View' created for the schedule so you can place it on your layouts.
Check the scale in the view settings.
Go to post
2 Replies 2
iggiv
YES!!!! I knew it was somewhere!!!
That you Barry. Has a nice week.
