2020-03-11 04:00 PM - last edited on 2023-05-22 11:52 PM by Gordana Radonic
2021-03-09 01:36 PM
2021-03-09 03:16 PM
2021-03-10 11:44 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-08-13 02:08 PM
2021-08-17 04:13 PM
Minh Nguyen
GRAPHISOFT
2021-10-20 10:08 PM
Hi Minh,
Shortly after sending my last inquiry, the project was taken out of BIMcloud and saved as a standalone PLN. Well, today upon publishing a PDF, I noticed that some of the dimensions (which were placed months ago and haven't been edited since) are jumping around again. I saved & closed the file and then upon opening the PLN the next time, I opened with the repair option and overwrote the previous PLN with the repaired PLN. Some of the dimensions also jumped around in the repaired PLN. Only after opening each layout, selecting the drawing and then clicking "refresh" was I able to publish a PDF without dimension issues. This is unacceptable.
Please let me know if you have any other suggestions or if you would like me to send in a PLA for evaluation.
Thanks Minh.
Jeff
