gdford
Do Objects know they have an "Associated Label" attached?
Do objects know they have an associated label attached?
If so - can this be tested against?
It would be helpful to schedule all of the labels currently attached to an object.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
poco2013
Mentor
ASFAIK - labels are aware of their attached objects but objects are not aware of their labels -- EXCEPT for the text/autotext label. In that case there is a property called label text which can be used to schedule all objects with this label type. label text is under ID & categories. To filter based on this label being present just use -- label text is not blank ( enter nothing in the criteria field ) I believe that label text will only be available if all types is used -- don't know -- experiment
Gerry
Windows 11 - Visual Studio 2022; ArchiCAD 27
gdford
thanks!
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
