2023-05-25
02:57 AM
- last edited on
2023-05-26
02:32 PM
by
Rubia Torres
For us to show clear opening space in a door, is there a way to turn off the door leaf, but show the door frame?
a workaround i found was to turn off the door opening symbol in the MVO, but this only works when it's a simple solid leaf. but it doesn't work when the leaf has any trim/glazing/feature to it.
Construction Element Options in the MVO allows you to toggle the door display, but it turns on/off both the leaf & frame, but not one or the other.
Solved! Go to Solution.
2023-05-26 02:31 PM - edited 2023-05-26 02:53 PM
Hi @Gerry Leonor,
You can select an empty door leaf under the door settings:
However, if you don't want to change your door leaf type, you can use Graphic Overrides and Model View Options combined.
Step 1 - Hide the opening line:
Result after step 1 and with Graphic Overrides applied to display the door surfices white:
Step 2 - Change Model View Options settings, detail level of doors, to "simplified":
Result after step 2, with Graphic Overrides applied to display door surfices white:
Hope this heps.
Best,
Community Expert | GRAPHISOFT SE
Did you get a helpful answer on the forum?
Give it back to the Community by marking it as an accepted solution!
Hi @Gerry Leonor,
Hope this heps.
Best,
2023-05-29 12:56 AM
yep -- can confirm this works, thank you.
