Drawing Title - Problem?
We're creating a fresh template for AC 23 (having migrated the last few releases). Forgot how much work it is!
While creating a favorite for Drawing titles, it seems the settings have lost a few options. I can't find where you set a different text size for the title and the scale, for instance. The scale text overwhelms the title, and we usually set it much smaller.
Also, you used to be able to type the circle diameter in the settings box. Now you need to click on the actual circle and set it there, no settings in the info box. Is this correct or am I missing something?
Thanks
11 Replies 11
Brad Elliott
Bit the bullet and switched to 23 for Beam display reasons. I am having the same problem Steven was with the Title Texts setting creating a stubby line instead of being the length of the texts as it was in the past. Has anyone found a fix for this?
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Yes, but you have to go back and use the 22 version. The 23 version is broken. Karl posted the object somewhere here not too long ago. Also, see thread here: https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=69018&p=309813&hilit=title#p309813
Richard
AC26 (since AC6.0), Win10
