WEDWay
Drawing Titles have mind of their own Layout Sheets
This is an issue I have been having for a long time I finally decided to make a post about it.
When I add a drawing to the View Map to the a sheet in the Layout Book, the titles, more often than not, end up all over the place. Sometimes I have to "fit in window" so I can find the titles. I have searched the web and this forum for an answer and I have not found one.
I'd like my titles to follow and stick with the drawings. Any suggestions.
BIM Consultant / Host of The American Landscape Travel TV Show
ArchiCAD 25 / ArchiCAD User since AC6.5
27" iMac Pro 3 GHz 10 Core Intel Xeon W & MacBook Pro Retina 15-inch 2.4GHz Eight-Core i9
3 Replies 3
ryejuan
I found out that if you turn off the drawing titles and turn it back on it would stick to the bottom of the drawing box. 😎
WINDOWS 11 PRO
Gerry Leonor
it might have kept the same setting from a previously placed Drawing with it's title 47kms from it's drawing.
the way i worked around this was to simply create a Favourite for placing drawings. this locates the title right under the drawing when placed & you avoid having to manually move the title 47kms from some rando spot in the Layout.
https://discord.gg/XGHjyvutt8
ryejuan
another idea is to ditch the drawing title and setup a master layout with autotext place in specific locations where you would usually place your drawing titles. 😁
WINDOWS 11 PRO
