Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Drawing a Site Plan
Is it possible to draw a site plan using the degrees, minutes, and seconds like an engineer would?
1 REPLY 1
Stress Co_
Go: Archicad> Preferences> Working Units & levels: Set Angle Unit to "Surveyor's unit".
Draw a line: click start point, hit "A" and type the bearing (N 34 34 34 E), hit "R" and type the length. You may have to play with the bearing orientation to get it right.
Marc Corney, Architect
Red Canoe Architecture, P. A.
