Editing Detail Markers
Can anyone shed some light on how to select and edit the size of the detail marker.
All I can do is move the marker, move the reference symbol and change the reference symbol line length
9 Replies 9
If you use the square placing for the detail, select the detail and while on the arrow tool, Click and hold on either of the four hotspots. I dont think it works in AC8.1
Thanks for the response, works ok on 9. We are still running 8.1 on a current project and that feature isn't implemented yet. Any one have a suggestion?
Yes, 9.0 is much easier, but it is possible in 8.1 as well.
The marker of course is changed with the marker size parameters. It sounds like you are talking about the detail cloud or boundary. (I'm not sure what the right phrase is.)
First, under Options | Display Options, set "Detail Boundary" to "Show". This is the key.
Now, with any tool in 9.0, or any tool except arrow in 8.1 and earlier, mercedes an edge of the boundary as shown in the screenshot, and choose the stretch edge icon in the pop-up palette. Voila. You can also add points, etc. to change the shape.
The editable hotspots let you visually change the radius of the corners, angle of the marker, length of the marker-to-cloud line, etc.
PS The screenshot is 8.1 since that is what you have. In 9.0, things work pretty much the same way, but with the added benefit of different colors for editable hotspots.
Perfect!
Solved a small but annoying irritation. Now maybe they could make it easier to find in the manual .....
Maurice wrote:
Perfect!
If it makes you feel any better, I only discovered this a couple of months ago after similar cursing.
Maurice,
I Can't imagine how big the manual will be if they, include every thing ArchiCAD can do, its good to discover some tricks, and thanks to this forum, you'll find most of them here.
Thomas Holm
Thanks Karl! Much cursing here too!
Thanks karl for the tip on adjusting detail boundaries. I do not seem to be able to adjust the boundaries of detail markers that are linked to another detail, only the "parent" marker. Have you noticed this as well? Does anyone know of any methods to adjust the boundaries of linked markers? Thanks in advance.
Link
Nope. You've found another deficiency in the detail tool. To achieve what you want, adjust the shape of the original boundary, alt/option click on it and create your 'copy'. Then you and undo the original and repeat if necessary.
Don't forget to change your Detail Marker Polygon to 'Clipp Polygon' if you want the marker to match the boundary.
Link.
