Editing dimensions
Once a dimension line is created, if I edit the walls and the nodes no longer associate with crucial points is there a way to move just a node at a time without deleting the entire string and starting over?
You can add nodes by control-clicking on relevant points with the dimension string selected, then delete the specific points you no longer need (Shift-click on the node itself on the dimension line and delete, don't have the entire dimension line selected).
Hope this is what you're after.
Exactly perfect. Thank you.
