Elevation Settings
mkmaco1999
Hi Team i am currently new to Archicad. I have this issue where in elevation the grass hatch appears however I don't want that hatch to appear, however on one elevation it is okay but it appears on the other one. I have attached screenshots for reference.
If anyone can help that would be appreciated.
Thanks
1 REPLY 1
CosminF
It is a matter of matching the cut and uncut display settings between the two elevations.
maybe this will clarify it:
https://help.graphisoft.com/AC/27/INT/_AC27_Help/050_ViewsVB/050_ViewsVB-39.htm#XREF_10777_Model_App...
you need to edit the cut and uncut elements fill display to match the look you are going for.
hope this helps.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Setup info provided by author
