2006-08-15
08:38 PM
- last edited
Friday
Aruzhan Ilaikova
2006-08-15 09:16 PM
2006-08-15 09:52 PM
2006-08-15 10:15 PM
2006-08-22 08:06 AM
2006-08-22 12:51 PM
2006-08-22 03:22 PM
2006-08-22 04:55 PM
2006-08-22 05:00 PM
Scott wrote:Scott -- It is located within the Object Library 10\MACROS 10 \Marker Macros 10. I did compare the two scale objects, but didn't find any discrepancies that would indicate that there was anything wrong with the Graphic_Sc_NCS_drawTit.gsm script.
Laura,
I have been struggling with this as well, but I have not found the Graphic_Sc_NCS_drawTit object inorder to edit it, but if this can be found, comparing the code with the Graphic Scale NCS 10 object (which seems to work at all the scales you have mentioned) might solve the problem. If you have located the Graphic_Sc_NCS_drawTit.gsm file, please let me know where it find it, and I will continue my efforts to fix this
2006-08-22 05:35 PM
Archi wrote:Unless this file has been updated (I downloaded it 2 months ago), the Drawing Title object has the same error as the the one included in the AC10 library.
Download the example file from NCS-Office.
Check the drawing title.
If you like it, than use it.
