‎2006-08-15
08:38 PM
‎2025-02-07
03:33 PM
Aruzhan Ilaikova
‎2006-08-22 06:14 PM
‎2006-08-25 02:22 AM
‎2006-08-25 06:34 PM
Laura wrote:Scott wrote:Scott -- It is located within the Object Library 10\MACROS 10 \Marker Macros 10. I did compare the two scale objects, but didn't find any discrepancies that would indicate that there was anything wrong with the Graphic_Sc_NCS_drawTit.gsm script.
Laura,
I have been struggling with this as well, but I have not found the Graphic_Sc_NCS_drawTit object inorder to edit it, but if this can be found, comparing the code with the Graphic Scale NCS 10 object (which seems to work at all the scales you have mentioned) might solve the problem. If you have located the Graphic_Sc_NCS_drawTit.gsm file, please let me know where it find it, and I will continue my efforts to fix this
I will check the drawing title out from the NCS-Office Library...
‎2006-08-25 08:17 PM
Scott wrote:I hadn't had a problem with the 1/16" scale until yesterday.
I check most of my other scales, I'm only having this problem at 1 1/2" = 1'-0". Also Laura, did you explode, extract (or whatever they call it now) your library to find the Graphic_Sc_NCS_drawTit.gsm file? My library doesn't even show the folders you mentioned.
‎2006-08-31 07:18 PM
‎2006-08-31 07:49 PM
‎2006-10-13 02:19 AM
