Excessive redraw times for sections/elevations
Dave Jochum
Anybody else experiencing long update times for sections and elevations since the last Mac Sequoia update (15.3 with AC 28.0.2 build 3110)?
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
8 REPLIES 8
MitchD
I'm experiencing it under Windows 11 and AC28.0.2...
Sames files saved back to 26 or 27 are almost instant.
ArchiCAD 28 /// Win 11 Pro - Ultra 7 155H - 32GB RAM - RTX 4060 8GB /// Win 11 Pro - i7 12700 - 64GB RAM - RTX 3070 Ti 8GB
That's interesting. I noticed an increase with AC 28.0.3 and then a huge increase with the OS update. It looks like it's the old, OS changes a step ahead of AC code updates.
Dave Jochum
It's gotten profoundly worse. Now doing anything with a placed elevation or section on a layout is painful. To select and move a drawing on a layout brings the spinning beach ball AFTER a delay of 5-10 seconds where nothing happens. I'm calling Graphisoft Monday morning and will report here.
Dave Jochum
Sorry--Just realized I never posted after discovering the issue. My crazy re-draw times were caused by a bad legacy object (metal chain).
Dave Jochum
how did you discover that was the problem?
It was not a quick process. I talked with Graphisoft tech and then sent them a .pla. We had multiple call sessions. I have gsm objects from many years back and realized that they could be an issue. I just happened to open a view that had the layer turned off that had the bad object. Then it was just a matter of rigorous investigating.
Dave Jochum
damn, i expected as much... but hoped it was a simple process.
Unfortunately, no. If you suspect an object, look at older 3rd party ones. Good luck.
Dave Jochum
