We value your input!
Export multiple Graphic Overides & Model View Options
Aquavit
Hi I can only seem to do this one item at a time. Is there any way to export multiples, in the same way you can import multiple *.xml files.
thanks
AC26 3001 INT FULL - Laptop Win10 x64 - Intel i7-7920 HQ CPU @ 3.10GHz - NVIDIA Quadro P3000
Hi Aquavit,
You can export multiple attributes to an external .att file. Just go to the Attribute Managers, select and move them to the right column and click the "Export" button at the base of the Dialog.
Hope this helps.
Yes, it is possible to export Graphic Override Combinations and Model View Options Combinations only one by one. I suppose this is because you have to provide a file name for them, and for that, they must be exported individually.
You can make a wish for this feature, we can vote on it and if it gets enough support, we can submit it to Graphisoft for consideration.
I agree that it would be a useful feature.
If you do make a wish, please post its link in this thread.
Ooops!
Yes. It is not possible to export multiple ones.
I could swear a GO separator separator was in the Attribute Manager.
Perhaps I am a bit obsessed about my Dedicated Shared Resource File.
