Fill Pen Question
Is there a way to use a dashed line for the fill pen of a fill? I am working on "simple" a 2D section (not generated with the section tool) and I need to use dashed lines for some of the fills.
3 Replies 3
runxel
Just go into the settings of the fill, it's right there. First item.
This setting is only for the outline of the fill....the fill itself cannot be changed to dashed lines...but I found another solution - turned it gray.
Maybe this will help …
https://archicad-talk.graphisoft.com/viewtopic.php?p=40381#p309651
