Fill Pen Question
Is there a way to use a dashed line for the fill pen of a fill? I am working on "simple" a 2D section (not generated with the section tool) and I need to use dashed lines for some of the fills.
runxel
Hero
Just go into the settings of the fill, it's right there. First item.
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
This setting is only for the outline of the fill....the fill itself cannot be changed to dashed lines...but I found another solution - turned it gray.
Maybe this will help …
https://archicad-talk.graphisoft.com/viewtopic.php?p=40381#p309651
